I have a 1998 detached house with an integral single storey double garage built part in and part out of the side of the house. The house has a split CU with a 30mA RCD feeding 2 ring mains. One of the ring mains is looped into the garage where it feeds 2 double sockets and a single switched hanging light flex. I want to remove the light flex and fit 4 switched fluorescent battens.
Although I guess the wiring arrangement met the regs at the time the house was built, I am concerned that there is no separate mcb for the garage circuit on the main CU and even more concerned that the existing garage light is fed off a ring loop which has overcurrent protection of 32A!! It would be both very expensive and difficult to run a new circuit from the CU to the garage area which is diagonally opposite and at the other end of the house and it would also be very difficult to wire the garage light circuit into the main house lighting circuit. I am thinking therefore, of installing a Garage CU in the garage part of the house and connecting it to the ring loop that is there, effectively making that a fused spur. I would then be able to put the new lights on a more appropriate 6A mcb and the garage sockets would have their own overcurrent protection from a new 16A mcb. From my understanding of discrimination, I guess the Garage CU RCD would be largely redundant as the garage circuit as a whole emanates from the main CU 30A RCD. However, this must be better than the existing arrangement – mustn’t it? But is it legal and is this the only solution?
I would be very grateful for the views and advice of you experienced professionals out there because I really cannot see what else I can do, other than pay for an extremely expensive and disruptive rewire – just for better, safer lighting in the garage.
