Feb 18, 2008
118
On call and the socket rcbo is tripping when the shower gets turned on.i have traced the shower cable and it goes from db to switch to shower.there is nothing connected into the sockets it is on a 40 a rcbo the sockets are 32a
The socket rcbo trips but the shower one doesnt.
Any thoughts?
Has it ever worked before? If not then I would suspect the neutral for the shower is somehow connected to the sockets RCBO.
Continuity test should show that.
Any thoughts?
Any testing done to prove anything???????
Could it be a N-E fault on the 32A ring that is set off by the shower current? If so, a load in the 32A ring should cause trip too. Just a thought.
Reactions: Richard Burns
What he said^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
There has been a few posts recently about RCBO RCD tripping when circuits not connected to that RCD have been energised!
Richard Burns has put up a diagram explaining how this could happen I will see if I can find it.
Have you tested both circuits fully and checked for any loose conections including the main switch?
Checked both circuits all switches/sockets tightened up all connections ir tested both and greater than 299mohms on all tests both circuits.
Turn shower switch on sockets trip
I swapped the 2 rings round hoping it would trip the downstairs ring ie faulty rcbo but no kept tripping the upstairs.
Wouldnt a ramp test just tell how much of a fault current is lifting the rcbo?still cant figure out why a sepwrate circuit is causing it to trip
You are ahead of me ... the ramp test will help to find it if was on a hair trigger. You did that by changing RCBO :)
Can there be any connection between the cables of the ring and the shower somehow? Perhaps an IR check to confirm they are in fact independent?
Have you tested the shower itself? Out of interest, what make is the RCBO?
PS have you tested RCBO's with circuits disconnected, to ensure they are functioning correctly ?
I would get your earth clamp meter out and see what the leakage is.... you may be getting good IR results with appliances isolated but when they are turned on.....the leaking starts.....
Definitely need the shower switched on to test it.
What else is connected to the socket circuit which only comes on when the shower is on?
What is being leaked onto from the shower?
The fault must be located on the circuit that the RCBO is protecting i.e. the sockets, because, unless the shower is cross connected into the socket circuit, then the RCBO cannot react to a fault on the shower.
The shower being turned on and tripping the socket RCBO means (some of, >30mA) the shower current is passing through a fault on the socket circuit.
Maybe through sup bonding ?
It was a faulty table lamp on the socket circuit,still doesnt make sense though that it was only tripping when the shower was switched on.it would work all day fine until the ahower went on......
Shower tripping sockets rcbo
ThrownRazor25,
Wilko,
