Discuss SWA CLEATS IN WOODEN GARDEN SHED in the UK Electrical Forum area at ElectriciansForums.net
Is there any requirement or logic to using fire-retardant cable cleats for SWA inside a wooden shed?
There will be a 2 metre vertical run and a 3 metre horizontal run of 4mm 3 core SWA.
Cid's probly right but personally I don't see the point.
It's a wooden shed, if it's on fire then I see no benefit in having fire retardent clips whatsoever. There will be no one alive in it and no one entering.
If the wall which the swa is on is hot enough to melt pvc cleats, then trust me, there is no wall.
Bottom line is , the regs require fire proof fixings to prevent collapse.
As crazy as it seems to fit fire proof fixings to a wooden shed which would just go up like a tinder , just use metal to tick the box.
A bit of bandy will do the job.
Are firefighters going to enter your shed when its on fire and get entangled? No. Just clip it.
These guys might.........
We can fix a consumer unit to wood with the rear entry open for cables to enter, and the massive entry hole doesn't have to be sealed, but some people really think you can't use cleats in a wooden shed as it could be a fire risk. Not sure how many firemen would be going inside a burning shed to save the lawnmower.
The regulations simply state that wiring systems shall be constructed to prevent premature collapse in the event of fire, there is no mention of type of installation....shed....domestic....commercial....industrial. Nor does it say common sense can be applied,it's a blanket requirement no matter how daft it might seem. Hence the disagrees to some of the above posts. If you ignore the requirement it's a departure, your call if you want to justify it on your EIC.
Yeah I can justify it it's absolutely pointless
There's the answer, the wiring system will not collapse prematurely as the structure it is attached to will be in a state of collapse already by the time PVC cleats fail.
Also while no mention of the type of building, the intention is to prevent entanglement of emergency response personnel if they enter a building with a collapsed wiring system.
No firefighter is going to enter a shed other than to rescue a person and I can't recall there being a single case of shed based self immolation, so the whole discussion is moot.
Well it's mootier still as, in the infinitesimally small chance that a firefighter does enter and become entangled, who can prove what failed first and where.
This is so nonsensical I'm wondering if it's trolling?
Reply to SWA CLEATS IN WOODEN GARDEN SHED in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm looking to get the lionshare of a small shed wired before a friendly electrician does the needful. I'm a confident DIYer, but I would...
Hi guys, I have supplied my Shed with a 6mm SWA cable into a nice consumer unit. In there I have a 6Amp MCB for the lights and a 16 A supplying a...
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
As the title says, I am looking for a recommendation for an enclosure and gland arrangement to electrically isolate or divorce the earth/armouring...
5K
