A
accisej
Hi, I've recently moved into an apartment which has a hostmann economy 7 quartz water heater. Since moving in, it appears that I can't get the timer function to work properly. The water only heats using the boost option. The timer itself seems to be working fine, I can hear it ticking and see it's moving round, the light comes on early in the morning which suggests that it should be heating the water, but after the timer light goes out the water is still freezing cold. The water only gets hot after boosting it. Can anyone please recommend any solutions to what I can do to try and get the timer function to work and actually heat my water?
Thanks in advance
Thanks in advance
Indicator light is in parallel with output to off peak (bottom) immersion so it is gonna be off peak immersion thermostat or element has failed. Top element is seperate and is controlled by boost timer.
Horstmann Economy 7 Quartz Water Heater - Help?
DIY Electrical Advice
accisej,
TJ Anderson,
