any update?
for what its worth, my opinion is that while it may be totally safe and technically acceptable, they have cut corners to save time, which will result in a poor finish.
Reactions: Dave OCD and DPG
any update?
The plasterer cut corners, the spark could have a legitimate excuse for routing the SWA in front of the skirting board. We can't see behind it.
Reactions: spark 68
Plasterer . . . . Spark there’s only one way!
Realistically the work could be fine and nothing in the pictures bar the loose cable suggests anything is actually wrong. Yes, maybe rough cutting out and I would have used conduit but there's nothing that indicates it is dangerous. I even see a grommet on the box so it can't be that bad...
Also your plasterer is rubbish
any update?
Yep I think you're right on that one. They came Monday and sorted the sockets that had issues and have provided the certificates to show all relevant checks were done. They claimed a miscommunication and that they thought I wanted it all done in one go. Like you say the final product doesn't look great, but at least I can feel confident it's safe as we moved in yesterday. All in all wouldn't recommend them or use them again. Thanks for everyone's input :)
Glad things are looking more positive. Thanks for letting us know.
[QUOTE="essex, post: 1510925, member: 107635" I am not saying it is ok to rip someone off but I am saying that expectations of work quality will be linked to the price paid.
Pay peanuts, get monkeys.[/QUOTE]
What a load of nonsense
Using that logic the more someone is prepared to pay the higher the standard of work that is expected
I personally have always kept my prices as low as possible whilst maintaining my work standard at the upper end of high when compared to most others
It has also been well documented that high prices tend to be the remit of many if not all cowboy companies
Exactly Des,
If the spark had charged on the low side it would have been pay peanuts yada yada, if he had charged high then it would have been rip-off merchant, I don't see how the electrical firm could have won a fair trial on here :(
the plasterer looked crap but I digress, Essex knows F-all anyway so I am just ignoring him as ever/per usual , just like the good ol' days :)
I fill all my chases as standard. Feel stupid now with everyone saying its not a bad job. Why is that consumer unit practically sitting on the floor? To the OP how much did the job cost?
Reactions: Mindgirl
I hope this isn't one of yours ! Ring main Earths are one cable per terminal not two as in your picture
if you're referring to my last post/pic., then you're talking bolloX. separating the cpc's between terminals is only required with a hi-integrity earthing circuit. eg. with computers. check your eggs regs. and come back with a reason for your comment.
I rarely use both earth terminals.
just checked stuey's profile. he's new here. a good spanking and a megger on his testes will sort him out. :D:D:D:D.
You wanna be careful saying things like that. SWD would have a field day.
My reason is common sense most electronic devices use switchmode transformers which filter to earth .The regs state " which can be reasonably be expected to exceed 10ma " .Well it's your choice mate .But considering socket outlets come with two terminals !
It appears you have over reacted to a quite Justified statement .It wasn't meant as an insult to your work sorry if you took it that way . 543.7.2 ( 18 )
I've wanted to know how putting the RFC cpc's in separate earth terminals, assist in high integrity earthing, if someone could help me out.
Reactions: 123
Advice wanted - unhappy with rewire
Sarah123,
Stuey,
