This is actually mentioned in gn3 if it looks like the ring has not been altered and there are previous test results,however I’d always test it as standard.
Ah yes, that's it.
Personally I would always check but it may be a reason why this person hasn't on this particular EICR
Fair play Ian and Gaz, I've read GN3 enough and couldn't recall that in there. I'll still ignore it and test RFC end to ends everytime though :)
In this case, most likely because they took Zs's only and made the rest up in the van!!! :)
Earth leakage clamp was reading off the scale probably cause they had it around the line conductor only I expect lol
  • Funny
Reactions: DPG and SparkyChick
Baku, Azerbaijan
Advice on Unsatisfactory EICR report
naylorpd,
TJ Anderson,
