How would you prove, for example, 8 years after fitting a consumer unit, that it wasn't your work that caused an MCB to burn out due to a loose connection? If your client claimed no other person had worked on that board/circuit, and there was no obvious new work there, it would be difficult. So you would honour your lifetime guarantee?
Well, yeah, I would. If it was obvious to me that the board had not been touched since then why wouldn't I. But here's the thing, this has never happened to me and I suspect such a scenario has never happened to you either.
Let me turn the question around PM. You're a competent tradesman, confident in the quality of your work, you’ve just fitted a new consumer unit, you've fitted it with all due care and to manufacturers instructions. Why do you feel the need to underwrite your workmanship for just 12 months?
easy to determine if someone has been in a CU after you. fit a non-restickable seal over the joint in the CU. like them what you get on MFT at calibration.
Reactions: dodger421
Terminals can become loose over time from vibration, material creep, temperature fluctuations etc.
I would not guarantee beyond 12months without a caveat of regular maintenance and inspection.
you can buy a car with 5 year warranty, however it is not worth the paper its written on if you don’t have it serviced to manufacturers specifications and schedules.
And if fittings and the like fail, we have to change free of charge within first year, can we chase supplier for the collection and cost of refitting, awnser is no.
Reactions: Deleted account
Not quite true James.
If the manufacturers have fitted a faulty part, then as soon as they are aware they will recall the vehicle and sort it no matter how old the car or whether you have maintained it properly or not. There are often recalls when it becomes clear that a part is faulty or failing.
  • Optimistic
Reactions: James
This is why you need to put a mark up on materials, to cover this.
Andy b your still wrong in guaranteeing your work for 12 years, but your choice
Reactions: UNG
The more time that passes after I have installed a CU, the more likely it is that someone else will have worked on the installation. Anyone working on any installation will most likely open up the CU, and probably disconnect conductors as part of that work. Someone replaces a shower, fits a new light in the loft, and so on. At that point in time, my guarantee theoretically ends for the parts worked on, but I won't know that.
Should a loose connection result from that other work, and the MCB burn out, an unscrupulous client could, being unable/unwilling to contact the responsible electrician (or perhaps they did it themselves), and faced with the cost of a consumer unit replacement, call me up, pretend no other work has taken place, and insist that I honour my guarantee.
Within 12 months of fitting a CU, I will probably know the installation fairly well, having tested and inspected as part of the CU change, so it is likely i will spot any changes. After several years, not a chance.
As @James says, terminals can work their way loose over time, again the longer it is since installation, the more likely this is to happen.
But really, there isn't much need for a guarantee of longer than 1 year. Any faults as a result of my work are likely to show themselves in a fairly short space of time.
You are right though, this has never happened to me. I very rarely get call backs, and it's always due to faulty equipment or user error.
You will know if it's a mistake that you made, think about it, if you're called to a fault years later then it's not going to be down to you. What on earth could that fault be all those years later.
If you installed correctly then terminals working their way loose will not be down to you, so chargeable.
That's right.
So there you go, it hasn't happened to me either and probably no one else on this forum that does the work diligently.
So I ask the question, why would you try to discharge all responsibility for your workmanship a year and a day after installing it?
Call andy today no delay the diligent spark , 30 year guarantee, they defo wont believe you
Only joking, I hardly get called back either andy
I don't give a 30 year guarantee, my quotes do not even mention a guarantee.
Just simply that I'm confident enough of my own standards to not have to worry about if failing after 12 months.
I'm sorry that you feel you can't say the same about your work.
Never thought about it much , and when I did I came to conclusion that electrical equipment normally lasts a long time, it's robust enough
That's right.
There's not much more that I can add to what I have already said Andy. Consumer units get mucked around with. As you say, after years pass any fault isn't going to be my fault, so a long guarantee is pointless, and probably misleading to many.
Reactions: Risteard
I can't agree with your comment and the "lifetime" workmanship guarantee you claim
From experience all terminals work loose over time no matter how diligently they are tightened during installation.
With copper creep you can torque a terminal and 10 minutes later you can re-torque it and it will tighten a little bit more
It is not unusual to find terminals that are not as tight as they should be on a 2 year PPM or a 5 year EICR so without a regular maintenance visit yes problems can and will occur
Reactions: loz2754
Especially if the terminals are subjected to any thermal stress the heating and cooling/expansion contraction will loosen them.
Yh andy is away attending a call out from 5 years ago, hel be back later to tell if connctions have came loose..
IMO workman ship has a lifetime guarantee as long as regular EICRS are done and the installation isn’t abused or miss used. Lifetime being 25years.
and any works done after your works becomes the responsibility of next installer.
any existing materials (including cables and conductors) re used are not part of that guarantee.
who ever supplies new materials holds the guarantee on them. I normally extend any guarantee I give on materials to 3 years. but mark up is essential to make this Viable.
That’s reasonable.
Only joking Andy, most work is good for years, and if it's bad it's bad from start
Consumer unit
peevee,
MJPD29,
