mark641
33
egham
One of my jobs is to PAT electrical goods for a local charity. Recently we have
been given some touch lights. On all of these, the switch interrupts Neutral
only and Live is on all the time. Is this normal or should I condemn these lights?
Thank you, Mark
TL;DR
Touch lights: switch interrupts neutral only.
Are you saying there’s a live at the lampholder all the time?
Is polarity correct in the plug?
Reactions: Pete999
thank you for your reply, i will re-check.
Thank you, Mark
Us this by design, or has the lamp been connected correctly, L/N reversed?
I have re-checked. Polarity is correct at plug. Resistance from plug pin -- lamp socket pin:
live < 1 ohm, neutral > 2 MO. When plugged in with no bulb, the light pin is live.
Is this a necessary part of the way these things work? Without an electrical field around them when they are off, how would they detect that you want to switch them on?
Is it correct polarity at the socket outlet though?
The apparent reversed polarity has been shown up by the PAT tester, not by detecting a voltage on the lampholder when it's switched off.
The lamp would argumentably be safer if plugged into a socket was incorrectly wired.
My Ikea 3 step does have neutral to lamp holder continuity but happily works with polarity reversed . The 220V activate potential must be capacitivly derived .
..But Wired for neutral continuity , the activation surface shows Live to a volt stick , and does give a tingle !
(this is tech at its least clever)
Thank you for your reply. What I think should happen is: the base of the light should be energised at low voltage or via a large
resistor. When you touch it, a sub-lethal (I hope) current flows which the switch detects. (I am not going to try with wet hands.)
But I dont think the light pin should be live with < 1 ohm between it & the plug pin.
Reactions: static zap
Thank you for your replies. Polarity at socket was correct last time I tried, I will re-check. (We have had a new meter fitted ---
not by me). I dont think the COP says that PAs must be safe if plugged into a wrongly-wired socket.
Meanwhile, I have decided that these lights are definitely not safe.
Reactions: timhoward
mark641
egham
PATting touch lights
Electrical Testing & PAT Testing Forum
mark641,
mark641,
