Rustiness
Norfolk
Hello everyone.
I’m looking at installing a camera on my garage. The garage has a 16A breaker for the sockets and 6A for lighting.
Am I able to use some 1mm twin and earth to wire the camera straight into the 6A with the lighting?
Ryan
Yes, however remember to add a power supply as mains voltage straight into a ring camera makes a small but expensive bang!
Oh really? They advertise that you can replace existing outside lights with these cameras so I thought they could simply run on the same wiring.
Is there a power supply you could recommend?
Cheers.
Edit: So I forgot to mention I’m using their “hardwired kit”. Does this have the power supply built in? I’ll add a picture of the info on the kit.
Cheers.
Cheers.
Cheers.
My apologies, I had assumed (wrongly) that it was a ring doorbell
The camera is suitable for direct connection to the lighting circuit.
Reactions: mainline
My fault, I could have made it clearer.
Thanks for the help. :thumbsup:
Hello everyone.
Ryan
Hopefully there's an RCD feeding the garage Cu.
Reactions: James
Norfolk
Ring Spotlight Camera Wiring
UK
Rustiness,
mainline,
