- Mar 13, 2025
- 9
- 1
- 33
- United Kingdom
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
Why does my 200di diesel engine start when cold first time every time and not start when hot ( completely flat battery symptom ) battery tested and ok, 14.6v on tickover all earths cleaned and re-seated, an extra earth from chassis to engine block, new starter motor, new starter switch, I have even tried the battery from my daily driver which I know is good and still get the same symptoms. Could it be the wiring from the starter switch to the starter motor breaking down which is the only thing I haven't tested yet?
