ASteve
Gloucester, UK
Hi... I'm hoping that there is something obvious I am overlooking... but I can't imagine what it is. Any hints or tips would be very welcome.
My house was built in the late 1970s. Around 2012, a conservatory with a double skinned wall approx 18" tall was built. I bought the house in 2018. In the conservatory wall there are 4 double sockets, and a fused switch. A fan and light hang from the middle of the conservatory - this has a remote control and is isolated by the fused switch.
Everything has worked for about 7 years... then, recently, I noticed that both the sockets and light in the conservatory had stopped working at around the same time. I investigated my RCU - expecting that something had tripped... but nothing had. All the switches were in the "on" position - indicating no problem with earth-leakage on any of the circuits in my house.
While my memory, of the time when the sockets in the conservatory worked, might not be perfect... I think I remember that the conservatory circuit was part of the upstairs circuit - despite being ground-floor. Nothing on the RCU is labelled 'conservatory"... and everything except the conservatory electrics work perfectly. This suggests, to me, that my RCU and all modules are working properly... so, whatever is wrong with the conservatory electrics, I'm fairly sure it is not leaking to earth and isn't a short circuit... as both of these should have caused one circuit, at least, to have tripped at the RCU.
I've lifted my upstairs floorboards in the rooms in the house above the conservatory - but have not discovered any wiring going to the conservatory between the downstairs ceiling and the upstairs floor.
I got a multimeter and a tone-trace tool... and I've tried to use these to work out where the wiring is routed... and I've ended up very confused. The fuse in the switch is a 13A one - and is not blown... and the electrics in the conservatory don't work whether the switch is in the on or off positions.
Layout: If I imagine a clock face on my conservatory floor... I can walk into my conservatory at 6-o'clock through a wide doorway from the house. At 3 o-clock there are patio doors. Except where there are doorways, there's a low double-skinned wall - with the UPVC conservatory on top. The floor of the conservatory seems to be concrete - and there are ceramic floor tiles covering it. These can't be removed without replacing the entire floor. The floor in the house is also concrete. I don't think there’s any electrical cables buried in concrete floors - either in the conservatory or the house. On top of the low conservatory wall, there are windowsills - I can't see any way to remove them without demolishing the conservatory. The fused switch is at 4 o'clock... and there's a double socket at 5 o'clock both in the low conservatory wall. There are also double sockets (on the other side of the external conservatory door) at 9, 11 and 1 o'clock.
With the power to the entire house off, I unscrewed the fused switch at 4 o'clock - and the double socket at 5 o'clock... in the low wall between the house itself and the conservatory external door at 3 o'clock. There are two similarly heavy gauge twin-and-earth cables entering the back of the back-box through a grommet. The back boxes are sunk into the inner skin of the low conservatory wall, for the sockets and switch. This conservatory wall is not plastered - so there's no way to hide cables that way... they must run in the cavity between the inner and outer walls. The cables are not visible. The fused switch at 4 o'clock has one larger and one smaller twin-and-earth cable. I think the thicker cable at the switch puts live/neutral in common with live-neutral on the socket next to it. I think I've traced the thinner cable (using the tone-generator) along the low wall (towards the house) then behind the UPVC upright and UPVC bar for the roof up-to the centre of the roof - then inside the centre beam for the roof - and into the fan/light. I guessed that - I needed to trace the other heavier gauge cable entering at the back of the double socket - as, I assumed, this must be where the circuit is fed. This didn't go well.
When I use the tone-generator connected to Earth and either Neutral or Live... I get convincing evidence that the cable is in the cavity of the low conservatory wall... but I also get a fainter tone over the majority of the house - including places no-where near the cable - e.g. in the middle of the upstairs bedroom 2m from any wall and 1m from floor and ceiling. If I connect the tone generator to the live and neutral wires, it is only detectable over a more constrained region of the house... but it doesn't seem to to trace to anywhere near other sockets... and I can't find any junction boxes. Using the tone generator, in this configuration, I can establish evidence that all the sockets in the conservatory are connected to one-another... but I can't find where any of the conservatory wiring might be connected to mains electricity in the house. This makes no sense to me - as mains in the conservatory had worked perfectly until very recently. Before anyone asks... no DIY has been done between it working and not working.
While my tone-generator experiments were reasonably convincing in showing me that my conservatory sockets were connected in common... it also showed me that they weren't in common with other sockets - or with lighting circuits - in the house. This makes some sort of sense... because conservatory electrics don't work now... while house electrics do work. This leaves me completely bemused. I've looked inside the sockets in the house that are closest to the conservatory - but haven't found any loose/disconnected wires. If there is cabling from the conservatory entering the house, I'm unable to find where it runs. I'm extremely confused... and hesitant to think my conservatory has drawn a 240v supply from the supernatural realm... despite that seeming to be the only explanation that matches the evidence I've found.
I'd welcome any hints... but perhaps these questions are relevant:
  • What would be standard practise when adding electrical sockets to a conservatory where there's an existing (previously wired) house to which it adjoins?
  • Am I right in thinking that, if all the switches in my RCU are in the 'on' position - then the RCU is showing no fault? (I've only experienced RCU modules that trip on earth leakage... but, I assume, it's conceivable that the modules themselves could fail? Is there an easy way to test?
  • Would a professional electrician have better tools than my tone-generator/wand (which was cheap) for tracing wiring in a situation like this?
Am I missing something extremely obvious? Am I in a situation where I need a pro? (How expensive should I expect this to be if so?)
TL;DR
What would cause a fault like this? Extremely confused trying to trace cables.
Yea, an electrician will have better equipment to hunt down where the problem is, and more importantly, the experience to know what the readings are telling them.
As with any work, the original connection to existing wiring would have been done in the easiest and least disruptive route.
Which could be the downstairs sockets in the adjacent room, or indeed the upstairs… if it was easier.
The connection may be in the back of an existing socket, or from a joint box under the floor.
Check in the nearby rooms or the conservatory itself that there isn’t a switch fuse that’s simply been turned off, or fuse blown.
It may be that the conservatory is a fused spur off the house ring.
As with any work, the original connection to existing wiring would have been done in the easiest and least disruptive route. Which could be the downstairs sockets in the adjacent room, or indeed the upstairs… if it was easier.
Check in the nearby rooms or the conservatory itself that there isn’t a switch fuse that’s simply been turned off, or fuse blown. It may be that the conservatory is a fused spur off the house ring.
Thanks for the reply - though it mostly just confirms that I've got the problem I've got. Downstairs I don't think wiring could be sub-floor - as the floors are solid concrete. Upstairs there are floorboards - but having lifted them I can't find any wiring or junction boxes. I've looked inside all the nearest sockets... but nothing plausible-looking emerged. It was at this point I decided I was baffled.
From just your words, "It may be that the conservatory is a fused spur off the house ring." this scenario sounds likely to me... especially as there is a fused switch in the conservatory. I thought it was just for the light/fan - but, as that's remote controlled in normal use, the switch has been on all the time... so I might not have noticed if the switch also turned the sockets off.
I've checked the fuse in the switch in two ways: I checked it using a multimeter (it has low resistance) and I checked it by swapping it with the 13A fuse in a power drill. It checked out as OK both ways. While it seems a long-shot, perhaps the switch has failed... I guess I could verify this by (carefully) using a multi-meter - to find out if mains voltage is present at the switch. If the switch has failed, and if it is a switched spur... I guess I'd have found the fault. I remain bemused about where the cables might be routed in the conservatory. I can't see where they enter the house - upstairs or downstairs - in any of the 4 adjoining rooms. I also can't work out (if there's only one mains cable from the house to the conservatory) how the gap is bridged across the gap in the conservatory wall for the external doors.
If I give up - declaring this too difficult a puzzle for me... any idea how much I should be paying a professional electrician to tell me what's wrong?
This would indicate to me that if all the sockets have 2 cables (thicker ones), the conservatory is a radial circuit and the 'fused switch' is just to isolate the fan light (probably should be a 5A fuse though)
So as a radial circuit presumably fed from the ring circuit I would be looking for another 'fused switch' whereby the conservatory is de-rated from the 32A ring final circuit.
If you are sure there is nothing inside, is the an adjacent external point, socket or S/FCU where the conservatory could have been supplied from?
Thanks for your reply.
Yesterday, I admitted defeat... I accepted that I couldn't work out where the cables were routed and I couldn't find where the conservatory wiring was connected to mains electricity in the house. I hired a local electrical contractor to come in and 'fault find'. This didn't go as well as I had hoped.
The positive bit first. The electrical contractor also tells me that the switch is for a 5A circuit... so, I agree, the fuse should be 5A not 13A. This aligns with my recollection of how it worked when it worked. I had only wondered if it were a fuse for the spur because I expected there would need to be one of those.
When I had posted here, I had thought the wiring ran clockwise around my conservatory - from 7-o'clock (where it terminates) to 5-o'clock - then connected from 5-o'clock to the house. I had started to doubt this - as extensive effort with a cable tracer hadn't resulted in finding a plausible path for the cables using this assumption. My electrician tells me that the wiring runs from 5-o'clock (where it terminates) to 7-o'clock - where it used to connect to the house.
Thereafter, things get a lot murkier. My electrician couldn't find a spur wired into the back of any of the sockets in the house. Neither of us could find any switch/fuse for the spur - so... I think it's safe to say, there is no fuse/switch. My electrician couldn't go any further than mark the cable coming into the back-box of the first socket in the conservatory - confirming that the rest of the sockets in the conservatory are correctly wired and would work if this one does. In the other direction... the cable is not live. My electrician confirmed that he could find no fault at my RCU.
My electrician believes that there must be a junction box "somewhere" - but he can't tell me where it is located. He has hinted that my next step will be to investigate under the floor in my third upstairs room on that side of the house. When I lifted all the floorboards I could in this room (a couple of years ago) I didn't notice any junction box - but, perhaps I didn't notice something for which I was not actively looking at the time.
My electrician noticed a crack (about 3-5mm) in the conservatory wall - near the house... and thought that might be relevant. I had not previously noted it - and it had not been on the house survey 6 years ago. He suggested that the only explanation for the electrical fault would be that all three wires (Earth, Neutral and Live) had snapped at around the same time. I feel this sounds improbable - but I have a situation unlike any I've experienced before - so need to consider explanations that will seem unlikely to me.
My electrician suggested running a new fused spur to the conservatory... from the downstairs circuit. This installation is easily within my amateur-electrician abilities... but routing the cable... without destroying the aesthetics of the exposed brick wall - and without dismantling my conservatory... may well stretch my amateur-builder capabilities. Another problem I have with this plan is that it leaves me uncertain about what is going on at the other end of the wire that no-longer provides mains to the conservatory. If the cable has snapped (necessarily somewhere it can't be inspected) then there may be mains electricity on exposed wires. If there is a junction box (under the upstairs floor) then I feel I need to find it... and (at the very least) remove any snapped cable from the house's ring-main. Getting access under the floor on the only remaining upstairs room - on the correct side of the house... is a big job for me - but is the one, I think, I need to tackle next. Thereafter - I think I need to dismantle enough of my conservatory to gain access under the windowsill to the cavity for its wall. This should help with stripping out any failed cable - and should allow me to drill the house wall and install a new cable towards the existing closest socket in the house.... which I can turn into a fused spur.
I will be completely lost, again, if - when I lift the floorboards upstairs - I can't find the mooted junction box.
Did he do continuity checks back to the consumer unit to verify if either the live, neutral, earth or all three are broken?
He told me that he'd checked continuity and that all three are broken. I was nearby - but I wasn't looking over his shoulder while he did tests involving the consumer unit. I'm not 100% sure exactly how he tested continuity of the cable between the conservatory and the house - as we still only know where one end of it is located.
That all three wires are severed does sound 'improbable' - but, as my electrician said... "not strictly impossible". The idea that all three wires are severed would be consistent with the (very vague) results I got using my tone-generator cable-tracer. My electrician didn't use this kind of technology himself... and my interpretation of the cable-tracer tool is a bit uncertain. Whatever happened to the cable happened either in a cavity of a double-skinned brick wall - or between the ceiling of downstairs and the floorboards of upstairs - or between the UPVC frame to my conservatory and the house external wall - where they meet. The emergence of the fault did not coincide with any work on the house in any of these areas. The fault did not cause the RCD to trip.
I'm not sure how they have verified continuity. What I would do is test back to the consumer unit and if I had continuity on any of them progressively disconnect other associated conductors at the consumer unit until it disappears to narrow down the circuit it is on.
Your test sounds sensible in principle. I didn't see the exact test my electrician did - but he did have my consumer unit (RCD) open at the time. The problem is that no matter which circuits are switched on or off, there is no mains voltage at the socket... and, while I've not done my own tests to confirm, I'm told that all 3 wires (in the cable from the house to the conservatory) are broken/severed. [Yes, I know this sounds unlikely.]
Yesterday, I was cutting out floorboards from the third bedroom - trying to find a junction box. I've pretty-much eliminated the possibility that the cable runs from this room. I think I have found the cables running to upstairs and downstairs sockets. I intend to double-check my analysis using a contactless voltage tester that I need to buy today.
As my possible next-steps:
  • Cut out floorboards in the centre bedroom directly above the conservatory - verify where the wiring runs for the sockets in that room. Look again for the junction box my electrician believed to exist... look for any spur going towards the conservatory.
  • Dismantle (at least one side of) the conservatory (huge job) in order to remove the windowsill above the cavity wall in which I know there are cables. I'd start with the side on which my electrician believes to be the spur-supply side (this is the same side that aligns with all the circumstantial evidence I've amassed).
  • Get a long wire with crocodile clips - connect it to earth at the consumer unit and do my own continuity test with earth on the wire my electrician believes to be supply side in the conservatory [with power to the house off].
  • Remove wallpaper on the house wall closest to the conservatory wall (supply side). My hunch is that if the wall had been channelled when the conservatory was installed, I should be able to see a different colour of plaster. [Frustrating as it will force me to re-decorate a room.]
This is the problem we don't know how they have come to this conclusion. To say all three wires are "severed" indicates it has been cut or physically disconnected. Now you live in this house so how unlikely is it you have missed the process of these wires being "severed"?
Before you go Frank Spencer and pull your house apart we would like to know how they established all wires are severed.
How soon after this did the supply fail? I wonder if you could have disturbed something without realising it.
Why would you when you've employed a professional electrician to test for you? Although doesn't sound like you have much confidence in him/her!
Surely that is one of the most obvious places to look, if 'directly above'!
I could understand lack of continuity on L&N if switched via DP switch but the cpc should still be intact.
Any vermin or wasps nests?
Gloucester, UK
Baffling electrical fault... Any hints very welcome.
DIY Electrical Advice
ASteve,
DefyG,
