G
Guest123
Many thanks to nickblake for originally posting this in a thread.
Paper
  • Paper insulation
  • From the WW1 era
  • Very rare now in domestic wiring
  • Paper is somewhat hygroscopic
  • Pre-war paper cable is still in service in distribution networks, and causes a good deal of downtime
  • The polychlorinated bipehnyl (PCB) used in old paper insulation is toxic, and the insulation should not be handled with bare hands
Lead sheathed
  • Common in 1930s for socket circuits
  • Used as exterior farm cable well after that
  • Lead sheath does not make reliable earth connections
  • Rubber inner insulation
  • Tail rubber insulation tends to disintegrate, and muck accumulates on cable ends causing leakage
VIR
  • Vulcanised India Rubber insulated cable.
  • Along with imperial T&E, one of the most common historic wiring cables still in use
  • Comes in 2 forms:
    • Twisted pair, cotton/rubber insulated, with no outer sheath
    • singles drawn into conduit
  • Most VIR wiring doesn't include an earth wire, which is sometimes run as a separate uninsulated single.
  • Rated to 60C
  • Rubber insulation perishes, cracks & falls off
  • Properties with VIR cable are usually in urgent need of rewiring, and may represent a significant safety risk. However some of the Jute / Hessian reinforced rubber cables that are often seen on consumer unit incomers are still often relatively safe.
A good percentage of the remaining old VIR wiring is now in a dangerous condition, especially at termination points. It is common to see insulation that has fallen off, often leaving live & neutral conductors bare, unsupported and in very close proximity. In the worst cases 2 bare conductors can be found twisted round each other with nothing rigid to support them.
The outer insulation has failed on the black sheath of the cable, and in one place the insulation on the inner live wire has also cracked off. This cable is in a very poor state, and is unsafe.
The rule of thumb with old rubber wiring is
  • replace it as soon as possible
  • don't move it at all, even small movement sometimes causes shorts.
This situation is quite different to early American rubber wiring, which is usually still in sound condition, due to the use of a different rubber formulation.
TRS
  • Tough Rubber Sheath
  • Rubber insulated conductors with a rubber outer sheath
CTS
  • Cab Tyre Sheathed
  • Tinned copper conductors, each core insulated with VIR, & cab tyre outer sheath
  • Single, Flat Twin and Flat Triple
  • (I'm not familiar with this one, but presumably it looks like TRS)
Aluminium
  • Cheaper alternative to copper
  • Used from 1950s to 1970s, and old stock sometimes used into the 1980s.
  • The insulation & sheathing is mostly the same as T&E - PVC for decades, may be rubber on older cable.
  • A known fire risk
  • Aluminium cable creeps, oxidises & fractures, all of which can cause fires.
  • Requires special connections, do not connect to old ali cable using connectors intended for copper.
  • Al requires a larger conductor size than Cu for the same current rating
  • Presence of aluminium cable may be considered a material fact for insurance.
  • The main problem with ali cable is its thermal expansion coefficient. Repeated temperature cycling causes it to come loose at connection points, and it then oxidises, and aluminium oxide is an insulator. Bad connections generate excessive heat and fire can break out.
Copper Clad Aluminium
  • Each conductor has an aluminium core surrounded by copper
  • An attempt to improve the properties of ali cable
  • Significantly better than al, the surface oxidation problem is eliminated, creep reduced & the risk from cracking more or less eliminated
PBJ
  • PolyButyl Jute insulated cable
  • Rubberised Hessian appearance to the sheath.
  • The surface is these cables is quite uneven
  • Commonly used for mains incomer insulation
  • Lots of old PBJ is still safely in service
Imperial T&E
PVC twin
Older T&E wiring having similar construction to today's cables. Several versions exist:
  • 7/.029 T&E
    • imperial 7 stranded version of 2.5mm² T&E
    • used for socket circuits until unstranded 2.5mm T&E was introduced around 1970
    • strands are 0.029" diameter = 0.74mm
  • 3/.029 T&E
    • imperial 3 stranded version of 1mm² T&E
    • used for lighting circuits
    • 1/.044" unstranded lighting cable also used
  • Ashathene T&E
    • Precursor to PVC T&E
    • Lasts well
  • PVC outer VIR inner
    • an early T&E cable
    • where the inner rubber has failed, the tails can be sleeved
  • 2 core Twin
    • no earth, used for lighting circuits, or power circuits with a separate (usually uninsulated) single run alongside to provide an earth.
PVC and ashathene versions of this cable last well and are usually in good condition, but rubber does not last well long term.
PVC outer rubber inner cable can have its rubber ends sleeved to make it safe, as its only the ends where exposed to air where the rubber becomes brittle and falls off. Cable with rubber outer insulation can not be made safe this way.
I had some lead sheathed on a job - someone had used as a dropwire on POTS. Fascinating - thanks
Good post... dunno if DIY Wiki would be happy with it's use without a direct link though....
and guess what i came across last week original braided paper insulated cable from 1930's and guess what its still in use , cant do anything about it till the guys out of hospital bike crash , the elderly lady who lives in the house with the son has lost the plot , all she talks about is the war , so sad when i get in to do it ill gets some pics so watch this space
Lenny, great post, just one question, VIR cable = rewire ASAP, (my neighbours house has this. Frightening) TRS cable, does this also require a rewire?
Have a friend who needs a new CU in a bungalow, and they mentioned a rewire, but on inspection the cable looks fine. They don't want to spend money if not needed
I have read other post's and some say rewire, others say if it test OK leave it alone.
Your views please
Personally Id always advise a re-wire. Given the age of these installations, the vulcanised rubber will either have failed or will be failing, a quick inspection will normally locate crumbling coatings.
i know its over a week ago but im going to agree with graeme on this one VIR rubber needs rewiring as soon as possible as the rubber can disintegrate rapidly even if it does look in good condition ,easier to rewire than rebuild
As an apprentice I worked on a 2.5KV system that had 600V grade VIR laid in a wooden duct with hard wood cleats separating the cores. The whole duct was then filled with pitch. It was installed during WW2 it was still live and in use in the late 70’s. It was a bodge and codge job due to the war, but it kept on working so why mess about with it?
Reactions: 2 people
Up the loft of an old office one day doing a rewire.We thought everything was switched off . When one of the lads shouted fire! we saw an old lead covered cable catching fire it was from the office next door . We managed to get into the office next door and up there loft to see it burning just like the fuse on a stick of dynamite very lucky! If you see lead now it has to be replaced no questions asked !
What you going to do hold the property owner at gunpoint? You can only advise, doubly so if you’ve just come charging in from next door. The first shot would be at you, you caused the fault, your responsible!
My first house had lead sheathed, rubber insulated lighting wiring.
The rubber had perished and shorted out when I moved cables around in the loft!
Knob and tube wiring.
Gutta Percha insulated singles run individually on porcelain posts (knobs) and where they pass through walls or beams porcelain tubes. As an apprentice I disconnected the supply to a building wired like this before it was demolished.
And before any smart ar*e says any thing it’s not my kitchen wiring!
it was used for domestic as well
I had an old-boy customer (93) talking about Pyrotenex yesterday - spooky!
Has anyone come across Black pre-wired conduit??? Found in late 70s old people home. Nobody seems to know about this. well, not on www anyway. Please do let me know if you have any info about this wiring system and how reliable it was and why it just disappeared!! thanks!
I remember, as an apprentice with the post office (later to become BT) fixing faults on paper cable in manholes; thirty odd years ago London was full of this stuff.
Air is a very good insulator but why would you put paper cables underground in wet England? If there was nothing else to use I suppose?
VIR was only designed to last 15 yearsbefore needing to be replaced so strictly speaking there should be NONE of it still in service today. PVC/PVC imperial was designed only to last 25 years before needing to be replaced, man! is this sad or what, why am I typing this crap?
Very Useful list there Lenny!
Do you or anyone else know if they ever made (possibly in the 60's) Flat Cable (2 cores and earth - all stranded) with Black outer sheath? I've come across some that looks and feels like PVC and which appears to be in good condition (i.e. not crumbling in the style of VIR) - I guess its possible that it was from later than the 60's but the customer seems to think a lot of the wiring dates back to 1962.
Paper
Is this the diaelectric "oil" as I have heard it referred to that leaks out of some of these cables?
I came across an incoming mains cable in a building basement where this stuff had seaped down the cable and pooled on the floor.
This is very useful for me. I've got a test tomorrow in college, I've already passed my first practical of a two way lighting circuit, testing it and lighting that circuit up. IT WORKED, FIRST TIME and nobody died in the process.
This test tomorrow, i've been told is easy, but I dont work in the trade so any knowledge regarding lighting circuits and wiring would be welcome. For example one practice question was why are wires covered in PVC, so to stop any short circuits if they touched, that sort of thing.
Cheers
Well got a nice history lesson this week, and all I can say is "big up" to the sparks and more likely apprentices because this stuff was heavy....yes I rewired a property form lead sheathed...and it was still in use following a CU change in the last 10 years!!
Wouldn't fancy mauling that around to much. At least taking it out you can chop it in to lengths. No sutch luck putting it in.
Alyssa, this is a public forum. You may want to edit your location so it's a little less specific
By 'Asathene' are you referring to HDPE?. If so, I've seen insulation creep under stress leading to S/C's
Nick, did you ever do this job, and did you get pics?
I like the paper wire - good for authentic English heritage installations. They like that kind of stuff even if it means there being a safety hazard :0
The History Of Cable.
Tags Tags
cable
Guest123,
Stroppy,
