K
Kish
guys a quick but of help.... wiring a newly built porch.... taken power for socket and lighting from an existing socket on ground floor and added a spur 13A from which power goes to a double socket and then to a ceiling light then from there to the light switch... would this work?
Re: **Show Us Your Installs!!!**
Why not start a new thread instead of using this one?
Fuse down the lights below 10A. I assume you are using 3 plate for lighting because the switch after the light is a bit pointless otherwise! Test and certify the work correctly and you will know if it will work.
Hi Kish, I took you post from the other thread and made it into a new thread of its own for you.
If you are unsure if it will work you are probably better off getting an Electrician to do it.
13 Amp spur for new porch
Kish,
jamesBoater,
