Discuss Adding a socket to a garage circuit. in the DIY Electrical Advice area at ElectriciansForums.net
voltemort
Hi everyone,
I've got a garage with a circuit that looks like this:
I believe it's a radial circuit coming out of the MCB with a current rating of 20A. It goes in to a switch containing a 5A fuse (fused spur?). It then has two wires coming from it: one for a bulb, and the other for a socket.
I would like to add another socket in the garage. I'm thinking the simplest way would be to add a junction box before the current socket, and add the new socket from this junction box:
Would this be the best way to do it?
The wiring seems a bit odd with having the bulb wired in to a switch, but then having the garage door connected using the socket. So any advice in general for tidying up the current circuit would be appreciated.
I have some experience with DIY wiring, but I'm not a professional.
Seems quite normal if I read it right.
20A feeds the spur, and the live supply continues to the socket. The light comes off the load side of the spur.
You can branch off a radial circuit anywhere… so whatever is easy between a joint box or coming from the back of the socket.
Hi everyone,
If the sockets are surface mounted, then I would avoid using a junction box and join at the socket if possible.
I'm looking recreate a similar setup as shown in this picture:
I'd like to get these three things:
1. The tubing/piping/protector for the wiring.
2. The clips holding the pipe to the wall.
3. The connector connecting the pipe to the top of the socket.
I don't know what I'm searching for to find these three things.
Does anyone know what their correct names are and where I can buy them from?
I'm from the UK.
Screwfix was my friend. I believe these are the terms I was looking for:
1. Conduit Tube
2. Spacer Bar Saddles
3. Conduit Adaptor (not sure whether male or female is what I need though)
The one in your pic is female, but they are usually interchangeable.
The female version protrudes less into the box than the male, and provides a nice rounded edge for the cables. The male would be used if you were going into a fitting with a 20mm female thread, rather than just a 20mm hole.
For item 2, we professionals have been tasked with using metal saddles in case of premature collapse during a fire.
Firefighters can get tangled in copper cables once all the insulation, plastic pipe and saddles have melted away.
Reply to Adding a socket to a garage circuit. in the DIY Electrical Advice area at ElectriciansForums.net
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
Howdy, I'm looking for help with my plan to install an extra internal double socket and an external double waterproof socket to my garage. I...
Hi, I would like to add a new socket in the bedroom. Current room configuration: 3 existing sockets - wiring coming from the bottom (under the...
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
