Certainly will!
Btw it's not the "churchy" bit...that is all upstairs. It's just a kitchen, some toilets, 2 large meeting rooms and a creche which is all downstairs (or ground floor depending on which door you go in)
kevin strikes with cupboard built over CU???
Maybe it was that bearded bloke? I’m sure his dad was a posh joiner
Turn the power off at the 50A breaker, arrange a dead short on one of the circuits from the missing DB, station a few helpers around, then get someone to switch the power back on. DB will be where the big bang comes from.
I was actually thinking of reversing the polarity at the 50A breaker and joining the 0.09ohms lighting wire N with some 10mm bonding wire back to the MET.
The short length of 1.5mm N that is actually L becomes the fuse and where the fire starts is where the CU is?
Access trap in the floor?
Reactions: timhoward and James
There is a recently resurrected thread on daft places to find a fuse box…. Could add a photo there if this turns into “supremely daft” territory.
It's in the library with the lead pipe and Professor Plum. Then again I could be getting confused with something else.
No mate surely Rev Green with the candlestick in the cellar?!
I though it was Miss Scarlett in the Basement with a strap-on snap-on?
I suspect that if I could hear an answer, it would be something like:
1 Corinthians 2:5
"so that your faith might not rest on human wisdom, but on God’s power"
More likely Job 5:7
"Yet man is born to trouble, As the sparks fly upward"
Check that EFLI is exactly 666 ohms and let Lucifer do the rest 👹
  • Funny
Reactions: pc1966
You can always trust blokes with beards.
timhoward
Broke Internet
Supporter
Oswestry
Can't find a consumer unit....!
timhoward,
UNG,
