Discuss Dimmer to use with a LED pendant/chandelier that has 25 LED lights in the Lighting Forum area at ElectriciansForums.net
To be able to dim LED lamps two things need to align... the dimmer must be capable of modifying the mains in a way that is compatible with the LED driver and the driver itself must be capable of being dimmed.
The driver is either built into the lamp or, as is the case of that lamp, built into the unit that mounts the light to the ceiling and based on the fact you state it's not dimming... I would say it's not capable of being dimmed.
Thanks SparkyChick. It stated on the box that it was dimmable - and had the dimmable symbol. But with a regular led dimmer, it dims a little but makes a low humming noise 😮. Then when I dim a bit lower, all bulbs go off.
Reply to Dimmer to use with a LED pendant/chandelier that has 25 LED lights in the Lighting Forum area at ElectriciansForums.net
Good Morning, I've used this forum for advice many times but this is my first time posting so I hope that this community can help! We're...
Hi all. Slightly out of the ordinary, but I'm looking to replacing between 60 to 100 standard size E27 bulbs with LED equivalent. The catch is...
This is the second set which won't work to replace the current spots here in my kitchen. All they do is flash once quickly. I'm replacing...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
I really need help with this puzzler. First - I am moderately 'skilled' in day-to-day basic wiring. My puzzle: I am trying to replace a...
