Discuss Extending 6mm oven wire in the UK Electrical Forum area at ElectriciansForums.net
Rawsox8
Hello, so before we start ive done basic electric work at home, so please dont crucify me too much haha
Right, i have a dedicated fuse for the oven in the fuse box, so does that mean it has its own circuit i take it?!
My current setup is oven on an island, a walkway and hob (gas) on the other side of the kitchen. Im gutting my kitchen and want to put an induction hob where my gas one is (gas cut off by my mate whos a gas engineer) and an oven inderneath with a 10cm gap for air venting.
I was thinking i could get a joiner box to connect some more 10mm wire to the existing wire, run the wire under the floor in a plastic tube (incase i need to remove it in years to come save ripping the floor up) and connect the oven and hob to the one single 10mm wire with a 2 gang joining box (not correct name im sure ha.
Or am i being --- and just call a sparky out to wire me in a new pair of wires for hob and oven from the fuse box?!
I read somewhere that joining 10mm oven wire is fine with a joining box aslong as its not being buried in a wall so its visible for inspection.
Any thoughts?! And costs for this if i have to get en electrician out?!
You can not extend a hob from existing oven more then 2mters espacaily a hob.
New circuit would be in order, what is the rating of the hob.i would get a local spark in to sort it out.
From the title its says 'Extending 6mm oven wire' so not sure what benefit you are expecting by joining a 10mm cable to it??
Agree with buzz a new circuit from consumer unit.
Well i changed the description to 10mm as im not sure what size the grey cable is seems bigger than 6mm, but didnt change the title.
I will ring an electrician. Thanks
Reply to Extending 6mm oven wire in the UK Electrical Forum area at ElectriciansForums.net
I am replacing my under counter oven with a new 3kw one, oven is on its own circuit and isolation oven switch, the cable is either 4 or 6mm coming...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Hello, I’ve got an issue driving me crazy and can’t get anyone to figure it out as it’s not their issue. We had a new extension, single rear...
Hi, My current oven is hardwired to a fused connection plate with a 13Amp fuse inside and power switch. That is then connected to the MCB labelled...
Hello hope you can help I have a single oven 2.4kw max and a ceramic hob 6kw max I would like to put then both on the same circuit so i was...
