- Reaction score
- 3,010
Has anyone seen any of these last more that five years?
Even then the work involved in resolving issues becomes crazy expensive.
I think these are mostly specified by architects and no sane Spark would suggest them.
Here's some I had the misfortune to be asked to "get working", yeah right.
The circuit was supplied direct from a DB at source via a timeclock. From there was anyones guess, leaves in 2.5SWA arrives in 1.5 flexing flexi-con.
There were five of them surrounding this glass atrium with no obvious wiring route or source, they were all individually wired, not looped, so somewhere there was a buried JB where the SWA came in and the flex split off.
After much deliberation I found a solution that fit the clients budget.
The yellow cement does fade as it dries. I quite enjoyed this very therapeutic.
