NO. ! Obvious this post has brought up many different ways to discuss certain aspects of installation that we all knew anyway didn't we ?
It's in series. Numpty. From CU in house to socket in garden to a 13amp plug to shed then into shed CU and RCD and three MCBs. In my book Series. Can't be in parallel as the second circuit would start before first RCD ! Can't remove first RCD because it is protection for outside socket. But to be correct the shed should have had its own supply. But I knew this. So to be safe with the extenson feeding shed CU I wanted to check if there was a problem regarding Ze. So I received abuse from some NHs and some useful information from others. Also quite a bit of disagreement amongst your selves. ?.SELV ?
UOTE=Archy Styrigg;992820]:smilielol5:
[/QUOTE]
Reactions: 2 people
[/QUOTE]
Know
You really don't get it do you? You don't have 2 rcd of the same value in the same circuit
In all honesty and fairness I will withdraw from this blog which at times has brought the best and worst in the Electricians Forum. Thanks boys and girls. See what I can use to wind up next.....train setting
Reactions: 1 person
forgive me if i've missed it, but is the shed wood, or is it metal. if the former it should make a decent bonfire. if the latter, use it as an earthing system ( buried, of course).
Reactions: 1 person
Tel please
please what?
why????
Reactions: 2 people
i your case, i'd be inclined to make an exception, but wicked banter is expected. i can't let all my fans down, so ....:ciappa:
Reactions: 2 people
It's TYlectrix;992972]please what?[/QUOTE]
I tried to leave but you wanted me to stay !
Its a wendy house on a rsj base (rolled steel joist) of a wood construction purchased from Mother care as a end of season discount. Electrics not included lol. Do you want more ?
Yes please, how big is your brain? in mm2 will do :grin:
garden shed Ze
£££sjim,
Guest77,
