E
Eco Chap
I can't believe 150mm is deep enough! Is it running down the garden? It should be at least 600mm with a yellow "cable below" warning tape halfway down.
The 600mm is only a recommendation. It's up to the designer to assess the depth of the buried cable. If its not considered to be on agricultural land I.e. a crop field or passing under a vegetable patch ect then bury it as the designer chooses. Mind you can never tell what tomorrow brings so 600mm is always a good recommendation
