Discuss makita radio mod/fix in the UK Electrical Forum area at ElectriciansForums.net
ive been having trouble with the signal lately so a week ago i took it apart.
i found the connection from the aerial to the pcb had come off (bad soldering)
i grabbed the nearest bit of cable and soldered it up and its as good as new.
while i was at it i put a 12-5v transformer and switch in there feeding a usb port in the battery compartment.
now when i find the exact size diodes i need across the d- and d+ pins to get the required voltage to charge at 1amp ill be happy.
Bought a 12v cig lighter to usb adapter from poundworld (yes it was a pound) it works great would have thought all the parts you need are in the unit.
as for the insulation tape plaster I only use blue tape (as I work in food factorys) and thats the colour of the plasters they use. not heard of the carcinogens in the tape
To be honest it was 20 years ago , but it has just stuck with me .
it might work but it would charge slow unless you put a certain voltage on the data pins.
otherwise it will be limited to 500mah charge rate
Reply to makita radio mod/fix in the UK Electrical Forum area at ElectriciansForums.net
