B
brizospark
Guys,
Just wanted to see if I was around the right figure with this quote. Full Rewire, House Stripped back to bare bones, half the walls stone half are stud partition.
Price for labour only as the gear will be supplied
Let me know roughly how much you guys would be quoting, labour only mind
Lounge - Double Sockets 7
Lounge - Downlights 12
Lounge - Light Switch 2
Lounge - Wire and Connect Uplighter Kit 1
Study - Double Sockets 5
Study - Downlights 6
Study - Light Switch 2
Dining Room - Double Sockets 4
Dining Room - Downlights 12
Dining Room - Light Switch 2
Hall Lower - Double Socket 1
Hall Lower - Light Switch 2
Hall Lower - Downlights 4
Stair Lighting Kit - Wire and Connect 1
Upper Hall - Double Socket 1
Upper Hall - Downlight 8
Upper Hall - Light Switch 1
Vestibule - Double Socket 1
Vestibule - Downlight 4
Vestibule - Light Switch 1
Bathroom - Downlight 6
Bathroom - Light Switch 1
Bathroom - Extractor Fan 1
Bathroom - Extractor Fan Isolator 1
Bathroom - Shower Pump Spur 1
Ensuite - Downlight 6
Ensuite - Light Switch 1
Ensuite - Extractor Fan 1
Ensuite - Extractor Fan Isolator 1
Ensuite - Shower Pump Spur 1
Bedroom 1 - Double Socket 6
Bedroom 1 - Downlight 6
Bedroom 1 - Light Switch 1
Bedroom 2 - Double Socket 4
Bedroom 2 - Downlight 6
Bedroom 2 - Light Switch 1
Bedroom 3 - Double Socket 4
Bedroom 3 - Downlight 6
Bedroom 3 - Light Switch 1
Garage - Double Socket 2
Garage - Light Fitting 2
Garage - Light Switch 1
Utility Room - Double Socket 3
Utility Room - Light Fitting 1
Utility Room - Light Switch 1
Kitchen - Double Socket 6
Kitchen - Downlight 10
Kitchen - Light Switch 1
Kitchen - Grid Switch and Flex Outlet points for 6 x appliances/accent lighting 1
Install new consumer unit and upgrade meter tails 1
Upgrade equipotential bonding to gas and water services 1
Install 6mm SWA supply to garage 1
Install small consumer unit in garage 1
Install External Light x 8
What was your quote?
Without posting it, it makes it look like your trying to get someone to do it for you because you CBA lol.
Also, don't exepct many of the guys to announce their pricing strategies online.
Reactions: 1 person
I am one of those that don't discuss pricing.
However, you're not that far off what i'd be charging. Probably doesn't help that lol.
The 'project developer' is supplying all kit I just have to give them a list of materials
would only do it on day rate. if i am not supplying the kit and it turns out to be wrong or not there on time or absolute rubbish you would be wasting your time and money being onsite with nothing to do, and they would not give a monkeys.
if i do not have control of the materials then its day rate with a minimum of three hours to be paid per visit to ensure they do not call you back time and time again because they are disorganised.
also ensure when the job is complete and their cheap transformers start to fail you will not be expected to come out and replace them for free!
Reactions: 1 person
£4500 -£5000. then add 20% on top to cover being mucked about, and another 20% to cover your work being f***ed up by other trades.
Pricing Advice
Electrician Talk
brizospark,
telectrix,
