- Oct 13, 2020
- 34
- 5
- 83
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
Hi guys
I’ve been requested to replace a consumer unit but will need relocating lower within a tight cupboard.
I will be installing a box with din rail and terminals etc and running new cables to new unit.
Problem I have is that the meter and isolator is mounted on a board. The only way to reposition the board to acceptable location is to run cables behind board.
I know it’s not great practice but no other possible route. Just wondered what your opinions are.
Cheers guys.
Cheers guys.
