Discuss Sky Dish the only Aerial in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
S
SimpleSimon
Hi Guys
Just moved into a new house and got a few questions about what looks like my Sky dish being the only aerial in the house. Can't find any Coax output around the house just LNB outputs. The dish has a quad LNB connector and runs from the dish to a splitter which than goes to three bedrooms.
Downstairs is the living room there is the twin LNB cables for Sky which work fine. So my questions are
- What is the best way to get a TV signal to all rooms in the house?
- Do LNB and Coax cables work on different frequencies hence why when I plugged the LNB into the back of the "Aerial In" on the back of the TV it meant it wasn't being picked up.
- Is there some sort of Satellite receiver I can purchase to give out the right signal across the house?
Buy yourself a freesat box they can cost from ÂŁ50 upwards you will get all the +1 hour channels for ITV,C4,C5 and lots more only thing I am not sure about is if you have a quad LNB then you sould only have 4 points but you say you have 5 ie 3 bed and 2 for lounge.
Remember sat cable is not the same as tv ie you can run 3-4 TVs of an aerial so Sky+ needs 2 cables to LNB and that leaves you 2 spare
It is possible to combine TV signal from normal aerial (Freeview) into the same run of co-ax as the LNB feed from the sat. dish, using a loft box or diplexer. It all depends on what you have already and what you want at the end of it.
Reply to Sky Dish the only Aerial in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Hi all, Looking for some advice on first fix for sky and freesat TV, I've quoted a WF100 shotgun and a single to both bedrooms and lounge...
I have unexplained equipment and diagram for three separate connected f81 connectors. Each f81 connector is connected to single receiver to single...
I have moved into a new build house and need to set up my TV, Computer, Internet etc. I need to have a TV aerial installed. I am confused by the...
  • Locked
5K
Hi, Looking for some advice on the best way to do this. We are looking to add quad plates and LAN to rooms throughout the house. Most rooms will...
