I have a 240v spa pump that won't run. No buzz, no hum, not a peep out of it. I removed the pump and disconnected the wires from it, leaving the cable plugged into the spa pack. When turned on I get the following voltages: (measured at the loose wires I disconnected from the pump)
black to ground - 120v
white to ground - 120v
White to black - 240v
Anyway I ended up replacing the pump but the new one won't run either. Took the same measurements and got the same readings.
I'm beyond mystified by this one. If anyone has an idea I would appreciate it.
Thx
Thx
Could you please send a picture of the name plate on the motor and are you using just a breaker or a contactor with overloads protection?
Thank you. Attaching the pump label pic and spa pack schematic. Note with the spa pack turned on and the pump connected I get 0v L1 to L2 measured at the pump. Whole unit is fed by a 50a GFI breaker.
Thx Chris
  • Hot Tub.PDF
    Hot Tub.PDF
SE Michigan
United States of America
Electrical Enthusiast (Unqualified Hobbyist etc)
If other, please explain
NA
Business Name
NA
Spa Pump Not Working
USA Electrical Forum
Thread Tags
Tags Tags
working
Chrisan,
Megawatt,
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
