B
blueboy
hello,
i don't suppose anyone knows why the electrical tests are done in a certain sequence do you?
thanks in advance
I'm sure a lot of people do :) Is this a study question or is there another reason you want to know this.
Welcome.
To get the best out of the forum its a good idea to offer up your thoughts so people can understand where you are coming from.
Reactions: 2 people
as you're new, i'll allow a bit of latitude. obviously dead tests before energising. then break that down a bit further. you don't IR test a circuit until you've determined that the circuit is complete. i.e. continuous. so continuity, the IR, then you know it's safe to powere up. then live tests, Zs, then test |RCD.
There is indeed a reason, a very important reason.
What you reckon ? Give it a shot.
Think about the sequence of tests and if they need to be energized and if you could do them if energized or not??? eg, r1+r2??? What would happen if you linked out Live and CPC then turn it on???
Ahh yeah, it would trip!
tests
Thread Tags
Tags Tags
tests
blueboy,
blueboy,
