HappyHippyDad
Supporter
Dec 18, 2011
5,378
6,731
405,788
Gloucestershire
United Kingdom
Todays job was to install an outside light.
Light installed, switch installed... time to connect to existing PL and N in garage light. Quick Zs, shouldn't be any problems as it's a fairly new build. No Zs!
I know, I know, I should have done this before hand. I've worked on this property before, it's well wired and it was a new build, I foolishly assumed it would be earthed properly.
Pinched an earth from a nearby socket and 1 hour later my new work has an earth ?. No extra charge as I should have done this as a pre-work check. I explain to the customer how good I am about making their garage lights safe.
Go to wire it into the batten holder in the garage, unscrew the earth terminal and I test the Zs again as I suddenly think just how unlikely it was that there was a broken cpc in this property...... I get a Zs reading!!!!
I then notice that the earth sleeving was a little too long and this had covered the copper when it was screwed into the earth terminal, hence no reading when I touched the earth terminal with my tester.
I remove my redundant new earth, connect up new light, stay quiet, collect money and scarper! ?
forthat, you deserve this. was going to hang on to it, but.....
No previous Initial Verification testing carried out on this property then, or pencil whipped from the van lol!
Shows the importance of testing. Good one.
How many times does this happen...& it’s like your fault..
HappyHippyDad
Supporter
Gloucestershire
United Kingdom
Today's job.
HappyHippyDad,
cliffed,
