None, oddly enough my arial in a weak signal area is in the loft and my pv pannels are between the front of my arial andthe transmitter i was prepaired to move the arial after the install but ive expeirenced a 1db rise in signal and quality!!
have the installers bent the aerial or damaged the coax?
Cheers, that's not what i would have expected! We've done 50+ installs now and not had a problem untill today. more likely bumped it off line i'm beginning to think.
Induced interference is usually only an issue where inverters have been mounted in close proximity to the aerial or the aerial cable where cable's screen is poorly terminated.
It is more likely that the aerial has been moved "off target" from the transmitter.
My installer announced the had fitted the last panel. I thought they had as the tv picture had dropped out. I had a loft aerial and had to move it. It is now within a metre of the inverter (SMA SB4000TL) and there is no interference at all. Hope this helps.
Thanks for the help, the aerial was moved higher up in the loft (by the customer) and all is well...
TV aerial interference
Thread Tags
Energetic,
Energetic,
