Discuss Using double pole RCD in the UK Electrical Forum area at ElectriciansForums.net
Is there anything preventing us from using these type of RCDs for a 55-0-55 circuit?
the picture shows the original set up.
OP perhaps you can clarify. Are you proposing to use the RCD to replace the Vigi residual tripping actuator but leave the original DP MCB in service, or what?
I suppose my question wasn’t clearly explained sorry for my mistake. The question I really wanted to ask is really other than the fact the RCD in the photo is mechanical interlocked with the D1 breaker would the RCD function for a 55-0-55 supply. I know normally we’d L-230v
N-0v Also am I being silly here but if you could get a RCBO that size could that be fitted? Also what is the reason for this kind of set up overload protection and additional protection?
Reply to Using double pole RCD in the UK Electrical Forum area at ElectriciansForums.net
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
Wallbox Fuse Box Lite Single Phase has anyone used one of these? I've installed one feeding a Pulsar Max, the Pulsar Max is set to 32Amp max. The...
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
I need to replace a Hagar RCD (model number CN284U). This is a type AC RCD and I wish to replace it with a type A. The model number for the Type...
4K
Hello! I've been racking my brain this evening about some RCD selections. I've been doing some work for a solar installer, and they've asked me...
