Discuss wago 773 in the UK Electrical Forum area at ElectriciansForums.net
In theory yes, as each leg of a 32A RFC should be capable of carrying 20A.
Depends on other issues too though, conductor size/enclosure/location etc and is so are they MF rated
Reply to wago 773 in the UK Electrical Forum area at ElectriciansForums.net
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
Hi, I need to swap out a damaged 30A junction box on an existing ring main circuit and thought I'd replace it with Wago 221 connectors and a Wago...
Hi All, As a householder I'm keen to add a double socket further along a wall to extend access in a different corner of the room. I'm connecting...
Been using Wagos since they came out, love them, but was wondering do you use them in poured resin submarine joints. Obviously if the resin had...
Good evening. Currently sorting out my girlfriend’s flat for rent. I’ve found all sorts of bad electrical work. Can anyone advise if this is an...
