Discuss what size rated RCD to use as main switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
An RCD used as a main switch should be an S type, and i cant begin to tell you the regs you are breaking by using one RCD!!! Seperation of circuits to avoid inconvenience and danger? Smoke alarm not being on same RCD as sockets? (assuming theres one there!)
Just wondering why you would be doing this? Why not put a twin or triple split load in with two seperate RCD's and possibly RCBO (again assuming smokes) and sign it off on 17th edition paperwork!!!
On a TT system with a split board or if 2x rcd's run in series then yes I agree an S type should be used.
Go on it would help those that dont know. The only one that I can see that might possibly at a push be considered a regs breaker (in a domestic enviroment anyway) is 314-01-01 (i)
Added to that why manufacture cu's with rcd's as mainswitches :confused:
Happens all the time on TT supplies. Granted not always on 30mA side but even so the smokes are on an rcd.
Why wouldnt they manufacture cu's with RCD's as main switches??? We are only talking about using one RCD on a main domestic board to supply all circuits - a sub board supplying a small number of circuits could have a 30mA and comply.
And 314-01-01??? Regulations with zero's in?? you are SOOOOO 2007!!!!
And 'happens all the time'? So does running 4mm cable from the supplementary bonds in the bathroom back to the MET. And bonding radiators and the bloomin sink in the kitchen - but we are trying to discuss what SHOULD happen - not what sparks who dont know the regs pass off as accepteble work!!!!;)
As could any of the wylex such as the NHRS1904 (or any other brand) that uses a 100A 30mA rcd as the incomer. Seen as it has 19 ways why not use it for a domestic installation covering all circuits if you so wished (personaly I wouldnt but there you go).
Ok just for you 314.1 (i) or (iv)
Nothing wrong with 16th not untill July 1st anyway.
bonding the bloomin sink in the kitchen
You mean you dont do this ! JOKING :D
Yes quite ;)
Yes quite ;)
nothing wrong with the 16th AFTER 1st of July, as long as the job was designed before 1st of july.:rolleyes:
Once the 17th kicks in you will just have a main switch ten RCBO's for every circuit so that are all individually protected.
Why?
For most circumstances a dual split board with two 30mA rCD's protecting 4 or 5 ways each, then an RCBO at the end for your smokes will do
All RCBO's just works out expensive
Why not just make up a split load board, with an extra rcd, and break up the circuits like we currently do under 16th? s have the main switch, and the smokes circuits, and the RCD, for general things like boiler supply, lighting and cooker, then the next RCD have sockets and some lighting. so that way you will never loose all the lighting but only some and the smokes will always stay active. but on the other hand all smokes have to have battery backup anyway?!so it doesnt atter really on the board configurations.
I can just see that the 17th is gonna cause alot of problems. and personally i feel the 16th edition rules are some of the best, but just needed tweaking, like more RCD's on a 3/4 RCD split board. just seems stupidily over killed. i know protection is in the greatest interest, but the way things are going soon when you sneeze or fart in the wrong room in your house you'll loose power because one of your millions of RCBO's / RCD's has decided to trip.
I think SHAKEY needs to write an article about this, I'll try and gather all the true facts and get him to put one together.
about what in particular Luke?
Using an RCD as a main switch?
Split loads boards?
How boards will change under the 17th?
Personally, I think the best way is to ask a question and see what replies you get.:rolleyes:
The trouble with articles that are all the 'true facts', when examined, is that they are actually just a collection of peoples opinions on interpreations of the facts
So if you can write one, good luck, I look forward to reading it:)
Reply to what size rated RCD to use as main switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Can a domestic consumer unit feed another consumer unit, via the Main Switch. Details are: domestic property with 100A single phase supply...
Hi, thanks for reading this. Ive been asked to look at a job where the DNO connection (single phase 80A TT) is a long run to the final circuits...
When doing an EIC for an additional circuit (which only covers that circuit), does the 'main switch/switch-fuse/circuit-breaker/RCD' section refer...
Good evening, I wondered how the MCB between RCD and the Main switch is wired while watching this video. Photo attached. I assume a busbar link is...
My friend just moved into a new build flat and its for a disabled person with a hydraulic lift to go to the upper floor. There was/is a leak...
