Discuss What type of cert should i get in the UK Electrical Forum area at ElectriciansForums.net
Hi
Ive just had a garden lighting job installed by an electrician which basically means a 230volt armoured cable was run around my garden from an existing garden socket.At various location he has then fitted above ground rated boxes which he has wired 12volt transformers to and then he fitted the 12volt lights
He did come in to look at the fuse board to check for our RCD when he 1st come round and it looks like he has done a great job
I would like to know what type of certificate will I be getting I have looked on line but there seems to be loads of different types
I trust the guy I just want to make sure I know what Im getting or should be getting
Paul
agree with andy. minor works if no new circuit. also not notifiable to LABC under the dreaded part pee. should look something like :
MINOR ELECTRICAL INSTALLATION WORKS CERTIFICATE Form
did not have me glasses on when I read the post .
Reply to What type of cert should i get in the UK Electrical Forum area at ElectriciansForums.net
Good Afternoon All, I moved into a flat around 2 months ago. A few times only (maybe four times in the two months) I've turned on the kitchen...
Hello! I've been racking my brain this evening about some RCD selections. I've been doing some work for a solar installer, and they've asked me...
I decided to get solar panels, the inverter instructions say one can use type AC, so the existing 14 x RCBO CU seems OK, may be a good idea to fit...
