Discuss Why is my ignition key barrel courtesy light stuck on in the Auto Electrician Forum area at ElectriciansForums.net
My Proton Jumbuck Ute has the Ignition Key Barrel light permanently on. (it should light up when a door is opened and should turn off after about 10 - 20 seconds). The interior courtesy light is working as it should with the doors open or closed and the bonnet anti tamper switch doesn't seem to make a difference if connected or not (car alarm arms and disarms OK). Is there a condenser/relay to control the light? If so where would it be located? These Protons were of Mitsubishi Lancer/Colt/Mirage design. Anyone had experience with these cars?
Thanks Brian
Reply to Why is my ignition key barrel courtesy light stuck on in the Auto Electrician Forum area at ElectriciansForums.net
