T
tom79bmth
Hi all
Just a quick question what is the bs name for concentric cable that the db use for tncs and what size do they usually use on a single house thanks
If you have a look at cable manufacturers websites and search for concentric cable they will usually identify the appropriate British standard.
However since cables are covered by a variety of standards such as BEN60228 for the design of conductors for cables and BSEN60811 for test methods for insulation there may not be only one standard applicable.
The one I have just found as being the most commonly referred to is BS7870.
i think the cheeky monkey OP is craftily planning on using it as a cheap --- sub mains.
you disgust me.
;-D
If the OP pays me enough I’ll breach joint it in to the supply for him.
BTW Biff 35mm²Al/Cu is the usual now.
concentric cable ???
tom79bmth,
Richard Burns,
