Discuss Part P , DIYers and confusion in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Mr Skelton.
You are indeed correct. Just because someone has an opinion does not make it valid. That cuts both ways however.
I don't think I mentioned theft or criminal damage and don't see why you used it in your reply.
'Bottom line' wasn't referring to CPS membership fees. I am aware you are not a member of such. I was referring to a recent post of yours where you argued requirments for wholesale change to the system and 5 or 6 lines referred to Electrical Trainee lowering prices in the domestic market and only 1 line referenced public safety.
I am bound to be annoying to some members seeing as my stance on certain matters is in the minority, but as you have already stated opinions can be right or wrong. There is often a resistance to change, and when feelings are high this can persist.
If you personally find me annoying, then stop engaging with me, and I will do the same. I have no wish to converse with you but will attempt to defend myself from your continued attacks.
Mr Skelton.
Troll off numbnuts.
Welcome to my ignore list.
Mr Skelton.
I haven't worked out what your stance is yet, it seems to change daily lol
MDJ, I think it's just my viewpoint that the schemes are here to stay that winds some up.
As to my thoughts on many matters, I am learning, discussing and debating, and naturally my viewpoint on certain matters will shift as I do this.
Reply to Part P , DIYers and confusion in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
A friend of the family recently lost her husband to the big C so I need to be careful. Every small thing is sending her into tears so when her...
I don't fit alarms as my main job but have fitted quite a few over the years whilst we were doing the electrics side of things. I usually fit the...
Just to be clear… I am going to do the correct thing here and pay for the correct parts…. I just wanted to start the discussion. My particular...
I've just picked one of these up on a famous auction site. The voltages, low and high resistance ranges all appear to be working fine but it's not...
I have carried out home wiring for 60 years as a competent person, for the last 20 years, I employ a local electrician to check my work and sign...
