Currently reading:
Which consumer units are best
Discuss Which consumer units are best in the UK Electrical Forum area at ElectriciansForums.net
I have a very old Wylex fuse board which is need to bring up to current standard Amendment 3.
I believe my property is supplied using a TN-S
I'm looking for a new consumer unit that is 11 or 12 way but not sure which brands are best as I plan on going for all rcbo.
So far I've seen Schneider, Hager and Wylex units
Schneider do one called Resi9 that's top of range but can't find any places that sell them, I can only see the Easy 9 for sale
Hager do one called Design 30
Wylex seem well stocked but I hear their rcbos are over sensitive and trip a lot, also they have had a recall in the past so I'm not sure on their quality in today's climate
I'm just wanting some advice on what you guys like to install, money isn't an object so I'm not after any budget stuff
Can anyone post pictures of their installs, be it cabinets or new metal consumer units
If my Son done that I'd rather fit MK outlets rather than rely on an RCD, IMHO MK have the best child proof shutters.
Theres no guarantee that a child or anyone receiving a shock would trip an RCD, and I'd prefer not to put that to the test.
It was in a 4 way bar at my mother in laws house. How is an MK outlet going to make any difference? Surely if you poke something in the earth at the top its going to open the shutters? I have MK Logic DP throughout my house, changed them all the week I moved in.
I believe these are the MK Logic plus
[/IMG]
Acti9? Why do these Schneider CU's have so many different names.
The only two I have seen advertised are the Easy9 and Resi9 although the Resi9 seems like gold dust
That Wylex one looks OK, which CU would you need for all rcbo's that can be mixed with mcb's? There are so many variations
Acti9 are their distribution boards
Easy9 are their consumer units
I would take a consumer unit to be a final board feeding circuits feeding current using equipment. I would take a distribution board as a main board feeding maybe several sub-boards or consumer units. Daz
a db is a consumer unit, just another name for them.
you get single and tpn 10 way+ consumer units under acti9
acti9 are merlin gerin
easy9 are square d
Or put another way, Acti9 is the series derived from the extremely popular and high quality Merlin Gerin Multi9 range, and Easy9 is some ---- derived from the old SquareD domae/qwikline garbage.
told ya dave
A consumer unit is a particular type of distribution board which is intended for simple single phase domestic use.
There are definitions in BS7671
No, BS7671 says 'principally domestic premises' - it is not exclusive. Although I still say that a dist board generally feeds distribution circuits to other sub-boards. Daz
yes and what im saying is acti9 Type A is a single phase only board thanks to the isobar so is technically a consumer unit as well
Are you certain that it has the type testing to be a consumer unit? Do they not make a direct connection kit for it?
If you really want to be pedantic it is an isobar4 distribution board which uses acti9 protection and control devices.
Reply to Which consumer units are best in the UK Electrical Forum area at ElectriciansForums.net
