• If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
R
Radventures
Hi there,
Basically, I'm converting a panel van. I'm planning to install two sets of LEDs & two mains sockets via a leisure battery/inverter/battery charger combo. I've been swatting up (thanks to much help from people on this forum!) and am almost ready to finish off the job. I'd love for someone to come out and tell me where I've gone wrong with it all, as I'm sure I have! Ie checking cable sizes/fuses/anything I may have accidentally overlooked before I plug it in and blow up the van.
If you could let me know when you're free (or I'm open to recommendations too) over the next week or so/rate/contact details it would be much obliged.
All the best,
Scott
as long as your fuse rating (In) is less than the current capacity (Iz) of the cable it protects, then the worst you'll get is a blown fuse, and if the actual design current (Ib) is less than In, youse laffin'
Why oh why can't the BS7671 put it like this!
Fuse placement?!?
As long as the fuse is at point of distribution should be fine.
(your protecting the cable you have just installed.)
bear in mind that for every amp you get out of an inverter @ 240V, you are pulling >20A from the 12V supply.
Electrican Help Needed on Van Conversion (Broad Town, Swindon)
Electrician Jobs
Electricians Jobs
Radventures,
telectrix,
