S
Sunil Patel
Hi,
I'm planning my wiring for my garage and can't find the answer easily for this question
my garage is connected to my house, there is a 2.5mm cable reel fed from the CU.
I will be supplying 7 double sockets and 2 led light fittings from this cable
I will put a 3amp FCU to supply the lights
and a 13amp FCU to supply an outside double socket (I want to be able to turn it off and on)
my issue is figuring out where to put my FCU's.
The best way for my plan is to run 6 double sockets then at the end fit a 13amp FCU supplying the outside double socket and then connecting the 3amp FCU to the LOAD side of the 13amp FCU and supplying the lights from there
alternatively I could supply the 3amp FCU from socket 5 and the 13amp FCU from socket 6
Which would be the correct method? or if neither could you help with a solution
Cheers
Cheers
