N
NeonSparks
just moved an mcb to rcd side of board and now a lighting radial on NON rcd side trips rcd...any ideas? I'lm sure i have moved correct wires.
Can't you put both lighting circuits on rcd side and note on cu about borrowed neutral if customer doesn't want to pay for fault finding?
If two circuits are sharing a neutral you can move both the circuits to the RCD side of the board along with their neutral(s) and peace and harmony should be restored.![]()
