Apr 1, 2023
Hertfordshire
Trainee Electrician
Fault finding- does any one know how many faults out of seven you need to find to pass the AM2S fault finding section ? any info would be helpful. Thanks
You need 5 out of 7 for a pass
Upvote 0
That's what they told me when I did my AM2 as long as everything else is fine (if you fail the safe isolation then that's an instant fail regardless of how many faults you identify correctly)
Upvote 0
Ok thanks dude, hopefully it’s still 5/7 as I’m sitting the AM2s exam and things have changed slightly
Upvote 0
Do you know by any chance if I have filled a box in wrong on my test cert will it be a fail even though I flew though all my testing ?
Upvote 0
Depends which box? I know they can be very strict with marking, If not keep going. Good luck.
Reactions: Luke1995
Upvote 0
It was the type of the supply I put n/a bit it is 2 which is like 2lines and one on bottom of top 😬 last day tomorrow everything went well. Just when I got home i realised, hopefully they will pass it. Thanks for your reply
Upvote 0
Hertfordshire
Trainee Electrician
Fault finding- AM2S. What is the pass mark for AM2s fault finding
John smith 95,
Luke1995,
Electrical Courses
