Jun 7, 2023
Texas
United States of America
Business Name
Texas Urban Sawmill
Greetings,
I'm a EE and have installed many electrical systems but am now dealing with my first large 3PH install on our property. I'm not formally trained in this area but very familiar as a EE. Anyway, can someone help me with proper neutral wire sizing?
I've done a bunch of research and am finding mixed answers. It comes down to this:
I'm planning on running 1000 MCM aluminum underground from a main disconnect at the pole to a MLO panel at our building about 400 feet away. This is for a 480V Wye Configuration with 400A meter.
I know the safe bet is to use a 1000 MCM for the neutral. But how do I go about proper sizing? I could save quite a bit of money if I'm allowed to run a smaller gauge wire for the neutral.
Greetings,
A good rule is size it at 83% of the 400 amp panel for a single family dwelling. So size it for 383 amps
I’m sorry it’s 332 amps
Greetings,
I also need to ask, is your building going to be used as a commercial building. If so you are not allowed to derate the neutral.
  • Informative
Reactions: pc1966
Apart from any regs that apply in your location, you need to understand the loads.
At one extreme, if all loads have non-complex waveforms then there's scope to reduce the neutral. At the other extreme, you could need a neutral larger than the phase conductors as third harmonics add rather than cancelling. Things like computer power supplies have got a lot better (for regs compliance) over the years, but flouros with magnetic have a very peaky current waveform.
Reactions: pc1966 and Megawatt
Texas
Business Name
Texas Urban Sawmill
480V 3PH Neutral Wire Sizing
Commercial Electrical Advice
dcg4403,
Simon47,
