- Nov 20, 2023
- 2
- 1
- 31
- United Kingdom
Hi all,
Has anyone here had any experiance of installing a Porsche 11kw 3ph EV wall charge unit ? We've not done many EV installs to date but the ones we have done have all had O-PEN protection built in to the units, (Easee)
The Porsche unit is basically a fancy looking empty box that comes with a 16a 5 pin 90 degree commando attached to the charge controller which docks inside,
so im expecting to have to provide the O-PEN protection by means of a Matt-e unit, and a 16a commando outlet housed inside the porsche wall charger.
