M
mary20
was in house today and all lights, sockets, shower, cooker are off same busbar and all neturals go to the same bar and is protected by and 63 amp fuse and 63amp breaker is this ok??
could be 6oA main fuse so would be ok....... isit a small apratment/flat 2 up 2 down, granny flat, as above a little more info could help us give you correct findings
I'm so sorry!! My internet connection went down. Depending on the TIME (ie year) it was installed, then the db situation could easily be appropriate for then but not for now.PS I wasn't for one second implying that you were an eejit, more me for not reading the question!!
Wellllll, ....It was certainly OK since the introduction of the Consumer Unit, that's what, ....for the past 65+ years or so!!
So tell us, what do you find wrong with this arrangement, apart from the fact that you only know split RCD CU's.
Have you given any thought to this question, like what would they have needed a split bus bar, neutral, earth bars for??
Hi Mary, nice to see a post from you. How is the trade in Ireland? Is there any sign of your economy picking up? I was concerned that we may have frightened you away. I can't add anything of value as I'm not familiar with your regulations. Best wishes, Mark.
House Fuse board
Australia
mary20,
MarkieSparkie,
