Discuss phase rotation testers in the UK Electrical Forum area at ElectriciansForums.net
yeah ive checked pm. we usually connect
l1 to u
l2 to v
l3 to w
but because we dont usually run a supply to our panels we don't know if the rotation will be correct
the direction it spins depends on the phase angle if i remember what my tutor was telling me, (poles usually 120o apart if 3 poles)
Eh?
What happens if you swap L2 & L3 say?
l1 to u
l2 to v
l3 to w
the direction it spins depends on the phase rotation if i remember what my tutor was telling me, (poles usually 120o apart if 3 poles)
:edit
phase rotation not angle as i was quite rightly picked up on.
getting my terminology mixed up lol
What if it's 4 pole ?:laugh3:
The sensible method is spin the motor before the coupling is fitted.
Get the rotation wrong on some pumps and compressors your going to be changing the unit.
Same here....more money making unnecessaries, IMO.
yeah jtl have a long list they want you to do.
if i miss anything ive got to do it in the training centre as a last resorts
Due to a hangover from the days of us having our own power station all the 11KV boards were BYR. We used 550V on the plants with the same rotation.
Then two new plants were build which were using this weird 433V. Some genius decided the rotation should be RYB. They were separate from the older plants so it didn’t matter.
Then it came to major alterations to one of the old plants. It was to retain 550V for some parts, 433 for the new stuff. Me being the resident idiot got lumbered with the job. First question, which rotation? Because it was overlapping with old stuff we went for BYR.
Again not really a problem as they were separate entities or so we thought. The plants spread out as they tend to and started to overlap. I got saddled with rebuilding a switchroom with 550V BYR, 433V RYB and 433V BYR. I was going dizzy! To add to the confusion the two 433V feeds could be interconnected.
Don't envy you mate, borrow a fluke T100 off someone and get the unit/task signed off no point spending coin on something that sounds like will never be used again by yourself
oh and take a little time to brush up on your motor theory too
Sounds like fun Tony, any oh **** moments or did it all turn on ok?
yeah i know i need to brush up, havent used some of the knowledge since i got my level3 cert back in 2012.
Reply to phase rotation testers in the UK Electrical Forum area at ElectriciansForums.net
