- Dec 17, 2009
- 58
- 13
- 83
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
I have seen few cases where the owner of a factory uses transformer after the grid to lower the voltage, from 240 to 220v as a way to lower the consumption and at the end to save money.
I was wondering if an inverter will do much better the job instead of a simple transformer as you can keep or change the settings any time you would want to.
For example,one case is a 3phase 100Amps transformer and transform the voltage from 240v to 220v.If lets say in the future the factory expand his land to the next plot he will have a bigger voltage drop so he will have to raise the voltage to 230v so to meet the standards.He will need to change the transformer or remove it.
With an inverter it should be simpler just a different setting on the output voltage.
Any thoughts ?
Any thoughts ?
