Discuss Add LED Spot lights to Kitchen Ceiling - how to run wires in the DIY Electrical Advice area at ElectriciansForums.net
M
mds1256
Hi
I want to add 6 spot lights (two rows of 3) to my kitchen.
It is a new build house and currently just has one light fitting in the centre of the room.
I was in the house as it was being built so I seen what was above the kitchen ceiling.
My question is how do I get the cables to each downlight fitting as the roof/floor joists? Will I have to break a hole through the ceiling at each joist to drill through or is there some gadget that could help me without damaging the roof too much?
I cannot lift the floor above as it is the bathroom and has a tiled floor.
breaking a hole through the ceiling at each joist to drill through is the only way if you can not get above sorry to say
Reply to Add LED Spot lights to Kitchen Ceiling - how to run wires in the DIY Electrical Advice area at ElectriciansForums.net
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
We bought a house with an array of broken (some cosmetic issues, some functional) downlights under cupboards in our kitchen. The bulb seem to be...
Hi, I need some advice on the wiring for a new ceiling light. I have taken down the original light, and I'm left with the wiring in the image...
Hello, Looking for DIY electrical advice. I have 7 x spots, and each are fitted with 1 x T&E connector block fitting [see photo]. In the past...
