- Apr 26, 2021
- 4
- 2
- 33
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Trainee Electrician
Hi guys.
so I’m running Ethernet cable and have a question.
the cable needs to pass through joists. There’s already 3 holes drilled (correct to building regs). I’d rather not drill another. Two of the holes have central heating pipes and the other is gas supply to the boiler.
there’s enough gap at the side of the gas pipe to pas the two Cat5e cables that I need but I’m unsure on if data cables need to be separate from gas as per mains cables. Anyone any thoughts?
Personally I can’t think of any reason why not but thought it best to check in case I’ve missed something. Checked BS7671 and can only find reference of data cables and mains cables.
TIA
TIA
