I’ve had a water feature installed in my garden, I’ve ran an swa from the garage cu to the water feature area and connected to the pumps rubber flex (wiska box and magic gel used). Although the connections are good, if there is a fault the rcd in the house will trip out. My question is could I install a 13a rcd fused spur in the garage instead of installing a new rcbo CU?
Mike
Mike
