R
Rob100989
I'm hoping this will be an easy one!
Ive just installed some fence lights and wired them using 3 core 2.5mm cable (overkill I know but I had a spare roll) to a choc block inside a junction box.
I also have some small LED deck lights that run via an LED driver and to a plug, however I have snipped off the plug and it turns out the LED power cable is 2 core braid type cable. Due to the lengths involved I've connected this via an in line connector to a piece of 2.5 mm and sheathed and taped the earth. This then runs to the same choc block in the junction box.
Both of these 2.5mm cables join to a single piece of 2.5mm which then plugd into an RCD protected outdoor socket.
It doesnt work ...
Can anybody tell me if there is anything obvious I have done wrong? My next step otherwise is to just take it all apart and reconnect.
Cheers,
Rob
Start with the basics:
1) have you got power at the socket?
2) plug fuse OK?
3) power at your junction box?
2) plug fuse OK?
I had to come in as it started hammering down but will investigate further tomorrow!
So theres nothing wrong with splitting a 3 core into a 3 and a 2? Or going from solid core wires to stranded type? One thing I've thought of is I havent disconnected the earth for the deck lights in the junction box although it shouldnt matter as I've done the other end right? Thanks in advance!
Garden lighting
DIY Electrical Advice
Thread Tags
Rob100989,
Rob100989,
