L
Lagentium
Evening all, bit of advice needed please. First time posting in this section because I don't really seem to come up against things that baffle me like this.
The job is an EICR on a production plant. Main supply to the plant doesn't have a neutral so someone has installed a 3 phase to the phase transformer which has a neutral connection on the secondary side to supply the lighting and small power, that is basically the premise of the job. The strange thing is that when I am testing I am getting a really high reading on the Ze and subsequent Zs readings. All insulation resistance and R1 and R2 values are where they should be. Due to me cross checking with the old test sheets as I go. The old test sheets, which are 7 years old. Have most test results around the 25 ohm mark. Now when I am testing I am getting around the 300 ohm mark? This is when the tester is set up in Zs RCD mode, when I press it and change the setup to Zs Loop I get readings around the 10 ohm mark. Tester is a Metrel 3125. Can someone please educate me please. I have a feeling it's to do with the TX regardless, but if someone can explain to me what's occurring I'd be chuffed. I even got one of the other lads to come down with his tester to check the results. I re checked my tester on another part of the site I had tested the other day and got the correct result in Zs RCD mode.
Baffled......thanks in advance
